Home > Maintenance & Mods (L322) > Rear Park Sensor Vogue SE 4.4 TDV8 2011
Dstew
PDC not working and there is a lost communication with rear right inner sensor fault code. Mechanic is going to remove bumper and hopefully reconnect sensor or trace broken wire. If it needs a new sensor which one would it be? Would like to have one at hand just in case while the bumper is off.
Regards
David
Post #577677 29th Dec 2020 5:44pm
DrRob
Common fault is the harness Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #577678 29th Dec 2020 5:48pm
Dstew
So I have read on this forum but the sensor in question does look like it may have had a knock. Hence asking which would be the correct one.
Regards
David
Post #577684 29th Dec 2020 6:20pm
kevinp
Look at site sponsor, Advanced Factors. Possibly LR038533.
Post #577699 29th Dec 2020 8:07pm
Dstew
Thanks for your help.
Post #577741 30th Dec 2020 11:03am
Dstew
Three broken wires in the harness. Now working perfectly.
Post #578550 5th Jan 2021 6:03pm
nino_nino
Dstewhow ,how did you get access to harness? 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #578563 5th Jan 2021 7:40pm
Dstew
I Paid Pegasus Garage near Sittingbourne Kent to do it. 😃
Post #578567 5th Jan 2021 7:52pm
Remove the rear bumper... Thumbs Up
Post #578607 6th Jan 2021 12:50am
nino_nino
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #578961 8th Jan 2021 11:19am
