Home > Technical (L322) > Gearbox service 2011 4.4tdv8
Graham Nic
Hi, I am looking at servicing the gearbox on my 2011 4.4tdv8, as she has just turned 150k, so looking for recommendations as to the best kit to purchase. Also as there is no dealer/garage locally that can perform a flush, is there a way to do it myself?
Been told to take off the cooler return pipe and to idle (after filter change and top-up) until you see a change in oil colour, then top up as normal?
So pardon my ignorance in asking if it's the top or bottom pipe that's the return?
Thank you in advance.
Graham
Post #577986 1st Jan 2021 4:03pm
GGDR
not sure but I did three complete changes just from the sump drain with a day or a long drive between. That way you have full fluid change. Changed the sump (filter) after the second one.
A bit tricky without a ramp.
. Cheers, Greg
Post #577993 1st Jan 2021 4:39pm
Mikey
3 drain and refills is not a full fluid change...
Post #578013 1st Jan 2021 7:15pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Where abouts are you
Post #578017 1st Jan 2021 7:50pm
GGDR
Fair enough Mikey Thumbs Up
. Cheers, Greg
Post #578027 1st Jan 2021 9:10pm
DrRob
Do yourself a favour and drive to Dundee and let Mikey at MMP do it for you.
Trust me. I’m a Dr.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #578036 1st Jan 2021 10:17pm
Fox889
Just googled 'Shetland to Dundee'..................14hrs Censored Holy Moly.
Ask Bodsey if he fancies a weeks holiday in Scotland & see what he says Rolling with laughter
On a serious note, a flush will replace 99% of the oil whereas a basic 'oil & filter' will only replace around 40% of the oil.
Logistically that means a diy effort, I suppose there's no harm in doing a couple of 'oil & filter' changes.....it's better than nothing.
The 4.4 TDV8 is a fussy animal & will probably bite you if it's not done properly. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #578065 2nd Jan 2021 9:54am
Graham Nic
The Shetland Isles
Post #578071 2nd Jan 2021 12:33pm
Graham Nic
Trust me. I’m a Dr.
Thanks, I might be coming down to the mainland this year, any idea how much they charge for a gearbox flush/service?
Post #578072 2nd Jan 2021 12:35pm
Graham Nic
Tell me about it? 14 hours on the ferry just to get to Aberdeen! Don't mind tackling it myself, but as I said in the original post, does anyone know which pipe is the return from the cooler, top or bottom and is this the easiest/best way to do a self flush? Also what kit is the best?
Post #578074 2nd Jan 2021 12:40pm
Weegie
PM Mikey and ask him. Smile John
GAP iiD BT-Sold
Post #578076 2nd Jan 2021 12:45pm
