Home > Technical (L322) > Heated seats and airbag light very odd
Sandyt
Well my good old fatty has completely bamboozled me this time I have been chasing an airbag fault for about 18 months it was /is intermittent last hit we checked all the wiring and connectors in the complete circuit and found only one corroded connector so all cleaned up it worked for a week then moved the rear seats and bingo light back on. At the same time the heated seats on the front stopped working changed switch pack fault still there cant find anything wrong so gave up then after 5 days sitting unused went out and bingo airbag light gone and heated seats working so god knows what is going on cause I dont
Post #578034 1st Jan 2021 9:58pm
This is a well know Range Rover phenomenon, if you leave it alone long enough it usually sorts itself out, don't worry, something else will fail soon... Thumbs Up
Although, if the airbag stores a fault it should direct you to the part of the system that is faulty... Pete
-Click here for Thread-
Post #578228 3rd Jan 2021 12:38pm
Sandyt
To be honest Pete I used the old trick of saying out loud near it that if the problems stayed it was going to be chopped in think I frightened it as its on nearly 200k Smile
Post #578610 6th Jan 2021 7:52am
