![]() | Home > Technical (L322) > IID Engine Live Values not showing |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
Go into first page, look for Live Values, select live values, then Complete List, then PCM-Engine TDV8. |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Many thanks, found it , but when I select view and look it shows
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
You need to choose the soot concentration inferred option if you want to check your soot level. Ignition need to be on in order to see the reading 2011 TDV8 Vogue SE |
Yep done that , still coming up as N/A
How old is your IID? Has it had all the software upgrades? |
IID is two months old. Have had them showing in the past, will check updates and try again |
You could try reflashing the firmware using the IID Updater tool. It will probably tell you that you already have the latest version if your unit is only 2 months old but it won't hurt to reflash it just to make sure all the software on the IID has installed properly 2011 TDV8 Vogue SE |
Thanks for everyone’s help.
