Home > Maintenance & Mods (L322) > IID Tool Battery Selection
Dstew
I have just fitted a Varta G14 AGM to my 2011 4.4 Vogue SE.
Have used Gap tool to confirm battery replacement.
How do I tell the car it now has an AGM battery?
Been into the CCF files for battery type but none of the options say AGM.
What should I be looking for?
Regards
David
Post #578718 6th Jan 2021 7:22pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
I think it can be found under:-
* Service / Test
* BCM - Body Control
* Battery Replacement 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #578726 6th Jan 2021 7:43pm
Dstew
Battery replacement just seems to tell the car it has a new battery.
Post #578728 6th Jan 2021 7:45pm
PeteT80
Mine was the same when I fitted a new G14, just battery replacement on my IID. The original Land Rover battery from new on mine was a AGM so maybe replacing like for like it doesn’t need to be told..
Post #578745 6th Jan 2021 8:57pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Indeed -- it should be AGM, so the car doesn't need to know it is AGM -- it just needs to know it's a new battery and alter the charging cycles accordingly (apparently) Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #578797 7th Jan 2021 12:07pm
