Home > Maintenance & Mods (L322) > Iid tool to put wipers in service mode
Landmark
Hi can I use iid tool to put wipers in service mode. 2010 l322 has no key so can't just turn off easily. It's to change the rear wiper blade really.
Post #578930 7th Jan 2021 9:46pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Just start the rear wiper then press button to open tailgate it will make it stop
Post #578931 7th Jan 2021 9:48pm
Landmark
I'll give it ago tomorrow, thanks for prompt response.
Post #578935 7th Jan 2021 10:07pm
kooky_guy
It takes some experimentation to get it to stop in the right position and you need to remember not to shut it again until you've completed the swap! 2010 4.4 TDV8 Vogue SE
Post #578955 8th Jan 2021 9:47am
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Follow this sequence with door open or closed.
1 Switch ignition on then immediately off.
2 Hold down wiper stalk while switching on, wipers front and rear go to park postion. Now change wipers leaving ignition on.
3 Wipers return to normal at ignition off.
Works on 2016 and think it works on other models aswell Thumbs Up
Ian.
Post #578966 8th Jan 2021 11:45am
