Home > Maintenance & Mods (L322) > Farmer’s hitch modification
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Thought I might share this. My detachable westfalia hitch was far too low for my ifor Williams, so I bought a farmers hitch to compensate. Alas, even on the top setting it was still too low! And hung down like an anchor. So the solution was to cut the bottom set of holes off which allowed it to go in upside down. Ifor Williams now sits perfectly level.
Post #579105 9th Jan 2021 8:25pm
Bluespanner
Apologies for the photo, not sure how I managed that. Perhaps a kindly moderator could sort it out for me
Post #579106 9th Jan 2021 8:26pm
My Indespension used to sit low but it was fine on my D4.
Caravan also sat slightly nose down but it was marginal. Good solution👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #579110 9th Jan 2021 8:46pm
re your pic..go to 'gallery' click on your 'my gallery' and select the pic and you can rotate it there.. ... - .- -.
Post #579115 9th Jan 2021 9:28pm
Thumbs Up good idea sir Thumbs Up
Post #579134 10th Jan 2021 3:10am
I'm trying to figure out what you've done - as it looks like the holes you have are now level with the piece that slots into the receiver..... If that's the case, there's no need to turn it upside down ?
Also, just so that you're aware - it will no longer be VOSA type approved & therefore in the event of an accident...... etc etc
I have no idea why the holes are as low as they are, or why there isn't a set of holes at the top, but it seems to have been deliberately designed that way.
Post #579140 10th Jan 2021 9:02am
Bluespanner
Well spotted Alistair. The holes I’ve used for the ball are ones I’ve drilled, otherwise the new lowest setting would have been to high if that makes sense.
Upside down to aid ground clearance, if I find a caravan or something that’s requiring a lower setting it’s only 3 bolts and I can flip it back over.
Cheers
Roland
Post #579146 10th Jan 2021 10:42am
Seems like a good solution - I could never really understand why there were not higher holes....
Post #579191 10th Jan 2021 4:49pm
