Home > Maintenance & Mods (L322) > Rusty upper bootlid
Danwilderspin
Rusty upper bootlid
Hi all my 07 has rust all along the bottom seem creeping up... it’s starting to look unsightly and is the only rust on the car bar surface rust underneath.
Anyone successfully contained and repaired this? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #579040 9th Jan 2021 10:30am
ur20v
A Trap
Expect repairs to last 18 months before blisters start to come back. Replacement is the only real cure.
Post #579042 9th Jan 2021 10:48am
Try and find a second hand tailgate from a pre 2006 car. Thumbs Up
Post #579044 9th Jan 2021 11:02am
mjdronfield
I got my 2011 car in Jan 2015.... and that seam had already been worked on by someone and the paint done.
I put a second hand good one on my TD6 when that started to show, and that was still good when I sold it.
Swap it for a good one if you can. Better than repairing.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #579046 9th Jan 2021 11:39am
FYI a new one from JLR is £1,100............. Shocked Shocked Shocked Pete
Post #579057 9th Jan 2021 1:00pm
DrRob
We need Famous Four to build aluminium ones like they’ve do for Classics
http://www.rangerovertailgates.com/
I have an Ali one on my Classic. Looks brand new still after 15 years Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579060 9th Jan 2021 1:22pm
Baltic Blue
I bought my 2011 in 2015 (so 4 years old ) and the upper tailgate was so rusty that they didn’t even argue when I pointed it out , they just said ,we will replace it under warranty.
The replacement is full of Dinitrol, so hopefully it should last .
Post #579061 9th Jan 2021 1:29pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
My 2010 when I bought it was rust free and the first job I did was use Dinitrol inside tailgate so far so good 7 years and still good
Post #579096 9th Jan 2021 5:56pm
BMW era RangeRover tailgates can last at least 16 ¹/₂ years rust free that I know of. Thumbs Up
Post #579098 9th Jan 2021 6:20pm
My 07 and 12 were both replaced under warranty due to rust. Chartwells who did them filled both with cavity wax and neither rusted again in the time I had them.
I would go with buying a good second hand one and waxing it up as you won’t have to faff about with glass etc and if you can get one in the right colour then you are golden! There is nothing that can't be fixed with a hammer😜😜
Post #579100 9th Jan 2021 6:47pm
Danwilderspin
Cheers guys as much as it pains me I will stick on this course for now then Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #579377 11th Jan 2021 10:06pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
My 2011 one was replaced under warranty a few months before it expired due to same reason , filled the new one with wax so hopefully won't be an issue again .
Post #579717 14th Jan 2021 11:28am
