Home > Technical (L322) > Error/fault codes
bigfatbloke
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Error/fault codes
Good evening gentlemen,
Can anyone explain the following fault codes please? And perhaps tell me which are bad and will need attention first?
UO100
UO300
U2002
U2003
C1104
U2002
U3000
PO562
UO155
PO561
PO702
UO401
UO402
UO403
UO416
UIA03
Any assistance is much appreciated. Thumbs Up
Post #580157 17th Jan 2021 8:08pm
Jayk69
google is your friend here just put the code is for example
U0100 brings up Lost Communication With ECM/PCM "A"
Read more at: https://www.obd-codes.com/u0100
if all those codes have come up at once you maybe should be looking at your battery. it would also help the forum members if we new what car you had 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #580164 17th Jan 2021 8:47pm
Jayk69
Just to add you have a P0562 which may be pointing to the Battery / Alternator this is a system voltage low code
https://www.obd-codes.com/p0562 2012 Vogue 4.4 TDV8 - Current
Post #580166 17th Jan 2021 8:50pm
DrRob
Clear them, drive around for a day or 2 and re read.
Most will be minor so clear and re read Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #580175 17th Jan 2021 10:07pm
bigfatbloke
Thanks for the info chaps. Much appreciated. Thumbs Up
Post #580319 18th Jan 2021 7:50pm
