![]() | Home > Maintenance & Mods (L322) > New owner 1st tow |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 938 ![]() ![]() |
My moneys on just needing a new battery. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
battery or alternator..
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
The bonnet/hood should stay up on its own. Get new struts.
Jmagg73 Member Since: 16 Jan 2021 Location: Illinois Posts: 33 ![]() ![]() ![]() |
Would the phone plugged into the lighter when car was off drain the battery?
Any suggestions on full set of struts? Will replace back window ones also. Looks like many options. |
Powerful UK do a twin set for hood and trunk
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Bought these struts recently. They work ok. No idea about their long term reliability.
Turns out just the battery. |
ok in trouble here. It's not the battery. Shop thinks its something to do with the alarm or the fob. It ran when the fob was in the cup holder area and turned off when moved. They don't have the stuff to mess with the alarm codes and say it should probably goto the LandRover Dealer shop.
oh geez. can it be that the low battery warning on the dash was the warning for a low fob battery? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
If it was the Key, it would say Key battery low. |
Tried new fob. Cranking over won't start. |
Off to the pros |
Turns out the fault codes were low pressure fuel pump circuit, and low pressure fuel sensor. They replaced the low pressure fuel sensor. Part number LR015356.
