Home > Maintenance & Mods (L322) > Rear washer issue
Dode4444
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Rear washer issue
Hi all,
First post so please be gentle.
This site has already proved a wealth of knowledge and information and has already helped me diagnose and fix my dodgy servotronic on the steering issue I had. But this next one seems slightly different to anything I’ve searched and read on here.
My new to me 2005 supercharged has a issue with the rear washer.
I have searched and seen they are a relatively common problem, but don’t know if mine is slightly different or a replacement is needed?
Have had the car around 2 weeks now and at first thought I was low on fluid.
The problem/issue is that although my rear washer is working...... it takes a good 7-10 seconds of activating before I see water coming over the back window.
At first I thought it was relatively normal or just a usual Range Rover quirk. But yesterday I noticed some tracks of the washer fluid on the trim on the inside of the rear tailgate panel.
So to recap, the wiper arm works perfectly fine and I am getting washer fluid but takes a lot of time to go through, and now seems to be leaking slightly.
I’m thinking my motor may be on its way out and slowly but surely failing???
If so does anyone know the part number/s I need to rectify the problem.
Thank you all in advance.
Post #582010 1st Feb 2021 3:50pm
Baltic Blue
Try changing the non return valve.
As a temporary fix on mine I used a valve from a garden centre intended for a plant watering system, it cost pence and is still working fine.
Post #582019 1st Feb 2021 4:53pm
Dode4444
Thanks, will look in to this. Would a faulty NRV cause a leak though? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #582023 1st Feb 2021 5:35pm
Baltic Blue
It can cause both of your problems.
If it is stuck half open pressure builds up when you keep using it, but when not in use water in the pipe drains back to the tank, meaning when you operate it, their is a longer delay whilst it refills the pipe the full length of the car.
Post #582027 1st Feb 2021 5:48pm
Dode4444
Thanks.
I’ll give it a go when the weather improves. 3 inch of snow at the moment.
Sad 😔 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #582038 1st Feb 2021 6:14pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
my 2005 does this its a pain in the ass hardly bother using any more Rolling with laughter just let the rain cleen it Rolling with laughter
Post #582046 1st Feb 2021 6:55pm
Dode4444
That’s exactly what I’ve done the last 200 miles or so Rolling with laughter 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #582054 1st Feb 2021 7:44pm
Jri711
United Kingdom 2010 Range Rover Vogue 4.4 V8 Santorini Black
I have the same problem on mine, would you know where the valve is located?
Post #582064 1st Feb 2021 8:48pm
Baltic Blue
Number 4 in diagram.
It’s all in the workshop manual, available free to download from the Wiki.
Mike.
Post #582065 1st Feb 2021 9:04pm
Dode4444
Mike.
Would something similar to these be ok instead of the £10-15 genuine part, these are around £2-3 if they do the same job?
Post #582425 5th Feb 2021 2:34am
Baltic Blue
They would be fine, just make sure to fit it the correct way round.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #582438 5th Feb 2021 9:30am
Dode4444
Perfect.
Appreciate the help 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #582442 5th Feb 2021 10:01am
