Home > Technical (L322) > Rear number plate light constant warning
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
I've got a couple of codes under the 'instruments' section of the iCarsoft reader for this, but no idea what they mean. Everything else seems to work fine and I changed the LED bulbs out for 2 others, then back to the original type with no difference and clearing the codes makes no difference
What ECU would be controlling this ? 2002 4.4BMW FF.
Thanks
Post #582118 2nd Feb 2021 2:02pm
Do your LED bulbs have resistors fitted to behave like normal bulbs? otherwise this error will be thrown when the car does its cold/hot checks. .
Post #582119 2nd Feb 2021 2:28pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
This is from the Electrical Library document
I hope it gives you a start
Light Check Module
The LCM (C2040) is located at the base of the RH 'A' post, and monitors the condition of the
fascia mounted rotary lighting switch (C0041) by providing a feed on an NB wire. The LCM
can determine the position of the switch by sensing if a feed is returned on a Y (side lamps)
or a B (headlamps) wire. The LCM also monitors the condition of the column mounted main/
dipped beam switch (C1832) via a U wire.
Side Lamps
If the LCM detects that side lamps have been selected, it provides a feed to the following:
 To the RH side lamp (C0537) on an SU wire
 To the LH side lamp (C0538) on an SG wire
 To the RH tail lamp (C0125) on an SW wire
 To the LH tail lamp (C0121) on an SP wire
 The rear number plate lamp (C1495) on an SN and an SB wire
 To the RH front side marker lamp (C0916) on an SU wire (NAS vehicles only)
 To the RH rear side marker lamp (C0918) on an SU wire (NAS vehicles only)
 To the LH front side marker lamp (C0917) on an SG wire (NAS vehicles only)
 To the LH rear side marker lamp (C0919) on an SG wire (NAS vehicles only). Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #582121 2nd Feb 2021 2:30pm
BMG
They've been fine for a year or more. I thought this might be the problem , so swapped them out for another two , made no difference. Did the same for the stock type of bulb and no difference.
I did go through all the different sections with the code reader when I got it and didn't have any under instruments, so this is new.
I guess unrelated, but this came on after I got a punctured tyre and had the tailgate open for 10-15 mins as I changed the wheel.
Post #582122 2nd Feb 2021 2:41pm
BMG
Light Check Module
Side Lamps
Cheers. Will do a bit of digging and see if its something cheap on eBay I can try swapping.
Post #582123 2nd Feb 2021 2:46pm
Have you checked for corrosion in the bulb holders?
Post #582128 2nd Feb 2021 3:48pm
