![]() | Home > Maintenance & Mods (L322) > Wiper Blades |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
For front wipers https://boltonbits.co.uk/aero-flat-front-w...-l322.html
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks Dunc, do you know if the rear has a special fixing? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Actually see they do a set of fronts and a rear so will go for that. Thanks for tip. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
No idea about the rear, unfortunately, but I'm watching this with interest because mine will need doing soon.
Yes have seen a number of options but these look like they will fit without issues. As I said I've got a set with the rear included so no doubt will have fun fitting that! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
To help change the rear blade, albeit on a 12my, but should work on an 09.
Where did you find the set with the rear included?
Dunc, this is the ebay number I used eBay Item No. 231130867728. They do an Aero blade set as well which is eBay Item No. 360919244512 bit more expensive but it's an option. Boltonbits is the seller.
Thank you. Aero blades ordered!
R V
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Nice i got a set of Bosch from Halford and the fitting kit was wrong completely so swapped them out for normal ones. 2012 Vogue 4.4 TDV8 - Current
Thanks Richard and Dunc will give it a go when the blades arrive. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1584 ![]() ![]() |
I replaced the rear last week. I used a blade from Allmakes P/N LR012047G
