![]() | Home > Technical (L322) > new oil cooler fitted under waranty smoke issue |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
It depends on how much you use it, took a couple of weeks on mine the oil gets all over the place. |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
i use it every day but only 20 min runs though, its going back in to the garage next friday to re flush the coolant there was a lot of oil in the the header tank is black, ill get then to check its still ok at the back, 2012 Range Rover Westminster 4.4 TDV8
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
Had to have mine flushed 4 or 5 times in the end. Took a few days for oil smell to go.
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 57 ![]() ![]() ![]() |
Mine took ages to get rid of the smell. I soaked it in “ chassis wash” mixed 50:50 sprayed down in the v with a garden sprayer let it soak and gently rinsed it off, all good now, paranoia can take over if your not careful!. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
If you’re using it for 20mins each day that’s a recipe for a DPF to start giving you issues. Take it for longer trips |
It gets a good run at least once a week 50 + mph for at least 30mins 2012 Range Rover Westminster 4.4 TDV8
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I replaced mine on Friday had a heart attack today got home from supermarket and smoke was billowing out but it smelt different |
