![]() | Home > Maintenance & Mods (L322) > What is this?? UPDATE!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
It's the heater control valve, they do a rebuild kit for it..
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 129 ![]() ![]() |
I replied to another thread asking how this is replaced, mine is caput - and I can barely reach it. |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Download the workshop manual from the Wiki, it’s under climate, heating & ventilation.
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Cheers, I will do a bit of reading.
I downloaded the WM from wiki, but when I look under the section of removal the writing next to points 3,4,5,6 is blank. Is this same for everyone or just me. I downloaded it twice to see if it was a download error. |
Ok, a bit of an update, I got the car on a ramp and looked from underneath and it seemed like the water leak was coming from one of the 3 pipes that come out of the back of the heater control valve. So ordered the 3 pipes, whilst changing one, might as well change all 3 while down there.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
I more than feel your pain. At the end of last year I had exactly the same leak and in the same spot!!
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 826 ![]() ![]() ![]() |
i like your style RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
Henryb2907 Member Since: 24 Jun 2024 Location: Norfolk Posts: 1 ![]() ![]() |
Hiya, I have traced a coolant leak to exactly the same spot. How did you get the 3 pipes out to replace them? Any tips or tricks? Looks like a |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1242 ![]() ![]() ![]() |
I'm in the same boat too, coolant flooding out just behind the heater valve block under the fuel filter assembly. Leak vastly reduces if the interior heater/cooler fan is switched off yet still empties itself after a minute or two.
