Home > Technical (L322) > codes
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
codes
just had the fuel pump leak fixed
connected the battery, turned the steering left to right
after about 10km the warning lights came on
the ABS light and i think DSC, it says DSC is in active
air suspension inactive
put my tester on it
steering incorrect CAN 0X09
ABS 0X0059
ABS 0X005A
ABS ECU fault 0X0015
is there a fault code list any where
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #585218 25th Feb 2021 3:31pm
knares
forgot to mention
when i first start the car, there are no warning lights on
they come on after about 3/5km RR 2005 4.4 petrol
Post #585233 25th Feb 2021 4:55pm
Ian G
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
Sounds unrelated to the fuel pump.
How is your wheel alignment and steering wheel angle?
Post #585287 25th Feb 2021 10:24pm
knares
"How is your wheel alignment and steering wheel angle?"
i did turn the wheel from one lock to the other
"steering incorrect CAN 0X09" comes up on my icarsoft
dont know how to check the rest, if there is any more to check RR 2005 4.4 petrol
Post #585325 26th Feb 2021 2:19am
Ian G
When you drive straight, is the wheel straight?
Post #585326 26th Feb 2021 2:31am
knares
i think it is, i will check RR 2005 4.4 petrol
Post #585328 26th Feb 2021 3:52am
knares
cant find these codes any ware
google codes all start with a P RR 2005 4.4 petrol
Post #585329 26th Feb 2021 3:54am
Ian G
P codes for generic OBDII which these are not.
Find the live data - will tell you far more about the plausibility of the sensor outputs.
Post #585330 26th Feb 2021 4:00am
