![]() | Home > Technical (L322) > 2011 tdv8 vehicle dynamic suspension live readings |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2751 ![]() ![]() |
The GAP tool doesn't have such a display. |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 ![]() ![]() ![]() |
Thanks for the reply,
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
What problem are you getting?
Hi Coopps
If a wiring fault occurs then you'll soon know about it from the displayed fault message. |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Have a look here, Sam measures the voltage whilst driving so might give you what you are looking for.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 552 ![]() ![]() |
Measuring voltage won't work.
There's no doubt that the current draw will increase as the duty cycle increases as the ecu reduces damping. |
Yeah, I have had a faulty sensor, but I am loooking more for being able to read the amps , and was wondering if the GAP showed this , it appears it does not. Thanks |
Who is measuring volts? Thanks |
That was the video I had rpeviously mentioned. He is measuring Amps not volts. Thanks |
Measuring voltage using an analogue meter will show a low voltage for a short pwm duty cycle and a higher voltage for a longer duty cycle but a digital meter will jump all over the place. Some digital meters have a pwm function, being able to display frequency and duty cycle. |
Bit snippy... But anyway, I was replying to dennij, who said: ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
