Home > Maintenance & Mods (L322) > L322 towbar electrics mounting plate
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
After my recent Wanted post, I managed to snag a used genuine LR/Westfalia towbar recently, but it doesn't have the mount plate for the electric socket. Because it's a detachable, I can't use the standard plate which bolts behind the towball so I need to find the right one. I presume in the attached pics that it bolts onto the two bolts show, which are at approx 20mm centres (although it looks much more in the pics for some reason!).
Does anyone know what the proper plate looks like and where I can find one? Failing that I guess I could buy the towball type and hack it to fit but I'd prefer the correct one!
TIA.
 5.0 S/C Autobiography - now gone to pastures new....
Post #586044 3rd Mar 2021 2:51pm
DrRob
Don't forget to seal the hell out of where it mounts to the body to stop water ingress. Known issue Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #586050 3rd Mar 2021 3:47pm
DrRob
Yes, towing electric socket attaches to that 2 bolt bracket Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #586051 3rd Mar 2021 3:48pm
bishbosh10
Just buy a generic plate and drill it to suit. Plenty come up on a Google search. Smile Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #586055 3rd Mar 2021 4:16pm
Cappo
Thanks for the tip Dr Rob.
Bishbosh, yes I'll do that if I need to but I suspect there must be a specific one and it would be nice to use that if I can find one! 5.0 S/C Autobiography - now gone to pastures new....
Post #586087 3rd Mar 2021 7:27pm
dhallworth
I bought a single towing socket bracket to fit the 13 pin electrics from Rob at Duckworths and it cost around 6 quid. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #586655 8th Mar 2021 12:25am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Re: L322 towbar electrics mounting plate
TIA.
Here's the bracket in the picture of the whole wiring kit like I have on my USA model. The one for your car in the UK may be different.
Here's a parts diagram from a European site that may show what you need. You'll need to take the number for the part (I think that's called the, "call out number") and Google for it. For example, I would Google for, "Land Rover 945509A" and look for a parts site that then lists the part number for that part. Then you can search for someplace that can get you the part!
You'll of course need to find what is the correct bracket for your connector. I'm guessing the UK will be different than here in the USA.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #586657 8th Mar 2021 2:35am
Cappo
Hi Larry, thanks for this detailed information. That bracket looks like it's exactly the item I need! I'll see whether I can track one down over here, that's really useful, thanks again. 5.0 S/C Autobiography - now gone to pastures new....
Post #586667 8th Mar 2021 10:18am
Cappo
Quick update: Rob at Duckworths cross-referenced the part number and I have one on order for a whole £6-ish! Thumbs Up 5.0 S/C Autobiography - now gone to pastures new....
Post #586883 9th Mar 2021 10:50pm
