Home > Technical (L322) > Air suspension lowering on its own...
Sleepy Jen
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
I need some advice please. My newly aquired 2008 TDV8 has been in my garage for over a week waiting for a new front brake caliper to arrive. I put the wheels back on it and lowered it back on the floor, leaving it at normal height. After three days the whole car has dropped about 3 or 4 cm. Is this normal? Also when I started it up, a message appeared on the dashboard saying "vehicle lifting slowly", could there ba an air leak? My carsoft code reader is not showing any faults.
Your help is much appreciated. Very Happy
Post #586382 5th Mar 2021 2:54pm
normally happens after you have jacked it up...take for a run and it should level itself.... ... - .- -.
Post #586384 5th Mar 2021 3:04pm
Sleepy Jen
Thanks Stan, the brake caliper I have been waiting for has just arrived! Car should be back on the road soon, I will post again when it is reassembled and I have taken it out for a drive.
Post #586385 5th Mar 2021 3:19pm
Sleepy Jen
All back to normal.
Thanks Stan.
Post #586529 6th Mar 2021 9:15pm
If you want to stop it next time, leave a door open, the interior lights will go off after around 15mins and the suspension will not try to level and lower each corner which is what happened to you... Thumbs Up Pete
-Click here for Thread-
Post #586541 6th Mar 2021 11:34pm
Weegie
With a door open press the light switch on the overhead console to turn off the interior lights. John
GAP iiD BT-Sold
Post #586555 7th Mar 2021 9:10am
