Home > Maintenance & Mods (L322) > Coolant query
Dode4444
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Coolant query
Can someone please confirm which coolant I need for my 4.2SC please?
Replacing the thermostat this week and will obviously lose some coolant.
Currently have a pink ish colour in the reservoir bottle if this helps.
 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #586671 8th Mar 2021 11:26am
If you put your registration number into Halfords it will tell you which ones will suit... Thumbs Up Pete
Post #586673 8th Mar 2021 11:44am
Dode4444
I did do that and Halfords comes up with the silicate variant where as I have read some posts on here saying I need the OAT type so was just trying to confirm.... 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #586675 8th Mar 2021 12:03pm
Dolphinboy
If you already have orange (OAT) in then use that. Don't mix as the blue and orange react and form a gel like substance which clogs the system (so I have reliably been informed). There is lots on here ref coolant so a search might provide further authority.
Post #586676 8th Mar 2021 12:11pm
Dode4444
Thanks for the replies folks, have searched several times and yet again get conflicting advice.
Some post say use the pink if that’s your normal colour already.
Others say the colours don’t necessarily mean you have oat or silicate etc.
Might just need to do a coolant change and then I know what’s in it for sure. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #586678 8th Mar 2021 12:15pm
D3Jon
Halfords checker can't be right as it comes up with every type of coolant under the sun for my FFRR when I put the registration in, G48, G40, OAT, Silicate based, etc. Don't know if that's just me?
So, try this checker from Comma, I've found it to be accurate for all my cars:
https://www.commaoil.com/
Also Opie Oils web site is very accurate, but can on occasion come up with only one suggestion (for example for my TDV8 4.4, they only suggest one specific Castrol antifreeze) :
https://www.opieoils.co.uk/
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #586679 8th Mar 2021 12:30pm
Dode4444
Halfords brings up silicate and g48 based on my reg number.
If this so true though that leads me to thing the red/pink coolant I have now is wrong but have seen it in other posts as being correct.....
Totally confused now Confused 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #586688 8th Mar 2021 2:13pm
Dolphinboy
Having just had my oil cooler changed by my outstanding, 25 yr LR experienced indie, along with a full coolant change, he has put this in. But mines a diesel 4.4TDV8 - just seen yours is a SC 4.2 so may be different.
Post #586690 8th Mar 2021 2:29pm
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
I use Prestone in any car I needed it for, it will mix with any car coolant no need to worry.
Halfords or toolstation sell it
Post #586693 8th Mar 2021 2:48pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Use OAT in mine. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #586708 8th Mar 2021 5:41pm
Dode4444
Thanks for the help and replies people.....
Seems like there are a wide range of people using different coolant and having no adverse affects. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #586716 8th Mar 2021 6:35pm
