Home > Maintenance & Mods (L405) > Oil Dilution percentage
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
A quick question as I have read all info I can find but can't find an answer to the question below, any information would be appreciated .
Would the fuel dilution percentage be reset to 0 if the service counter was reset without the oil actually being changed or would the percentage keep going up until the oil was actually changed.
Post #586779 9th Mar 2021 1:07pm
this thread is all voodoo science to me but it might answer your question,
https://www.fullfatrr.com/forum/topic52724...percentage ... - .- -.
Post #586783 9th Mar 2021 1:35pm
Baltic Blue
Sorry I can’t answer your question because I always rest service indicator as part of my oil and filter service, but I have started logging the rate at which dilution raises from Zero.
Unfortunately Covid lockdown has reduced my usage so it will take longer, but in 1000 miles it has risen fairly gradually from 0 to 0.48, ,so because the limit is 7 , my regular 6 monthly changes will give me peace of mind.
Post #586785 9th Mar 2021 1:49pm
154JON
Thanks for both answers, to explain the reason for my question is that about 2 months ago I got the service due message because its been 365 days since the car was serviced even though its only done about 6000 miles since the last service and all quite long journeys over 100 miles (I had not had any messages to say oil service due previously ), I had already seen a video that showed how to reset the service message so thought I would try it and it worked so message went away, recently i have read a few bits on hear about oil dilution and having treated myself to a Gap at Christmas thought today I would get the reading which has come up as oil quality fuel dilution factor 0.488 and distance since diesel partial filter regeneration 527km so was wondering if it was a true dilution reading or I have reset it in which case I will do an oil change to be safe. Very Happy
Post #586787 9th Mar 2021 2:05pm
diesel Dave
TBH I had the same quandary as you with low mileage this year, I decided to change the oil anyway as 12 Months or the stated mileage has always worked for me, a bit different now with DPF’s but the 12 Month marker should be adhered to IMO. Thumbs Up
Post #586831 9th Mar 2021 7:17pm
Dolphinboy
IIRC yes it will reset it to zero when you click service reset. I had a high reading of 12 oil/fuel dliution when I bought the. car and did an instant oil change and reset using my IID tool.
Don't worry if it gets a high reading again it will let you know!!
Post #586864 9th Mar 2021 9:27pm
Baltic Blue
My service required l warning flashed up yesterday.
It is 12 months since I last changed the oil and filter, but I have only done c800 miles due to lockdowns etc.
The oil dilution reading on my iid was 0.806.
I will be changing the oil and filter in the next couple of weeks as I always do a full service as part of my MOT preparation checks.
So I decided to reset the service indicator to get some definite readings.
The oil contamination now reads zero , even though I know it’s not been changed.
I intend to run it for a couple of weeks and keep checking it to see if it returns to 0.806 before I change it.
Post #595189 24th May 2021 2:54pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Probably an incredibly stupid question but ...
Using a GAP IID on my L405, can I see when the car was last serviced and at what mileage?
I've used the CCF functions of the tool before, but "playing" with the live values section makes me a tad nervous Laughing What do I put here then?
Post #620665 20th Jan 2022 11:20am
TJH1985
It resets back to 0% Thumbs Up AFAIK its a calculation rather than an actual reading. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #620678 20th Jan 2022 12:48pm
dunno about that but if it was serviced at a dealer with access to the JLR online service history then you can see on that site,
https://osh.landrover.com/ ... - .- -.
Post #620679 20th Jan 2022 12:49pm
Baltic Blue
GAC23,
Yes, most of the service history is available in live values if you look at the full list for the engine….
Miles since last service reset etc etc.
Post #620689 20th Jan 2022 2:29pm
GAC23
Thank you @Stan and @Baltic Blue.
I'll have a careful dabble then. What do I put here then?
Post #620692 20th Jan 2022 3:32pm
