Home > Technical (L322) > Replacement Key
Rodjules
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Replacement Key
So chaps, I have the chance to buy a Repossessed 2007 vse cheap enough to take a punt on not seeing it running (haven’t done anything silly yet this month !). What could possibly go wrong ? However trying to get my head around the no key bit and how I would go about a replacement, I have IID so guess I can program it to the car but what do I do about getting it cut to the barrel ?
All suggestions well received including the ones mocking my madness !!! 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
2012 L322 Range Rover 4.4 Westminster Baltic Blue, Ivory - Deceased
2012 Discovery 4 HSE 3.0 Sdv6 Oslo Grey, Black - Gone
2006 L322 Range Rover Td6 Vogue SE Buckingham Blue, Parchment - Gone
1996 P38 Range Rover 4.6 HSE Rioja Red, Black - Gone
1990 Landrover 110 2.5TD CSW - Why Oh Why ???
Post #586819 9th Mar 2021 6:35pm
Ianb4310
Try Boyd Beattie at pixels fixed he’ll be able to help you
Post #586824 9th Mar 2021 6:54pm
dhallworth
I don't think you'll be able to do anything with the IID until you've got a blade as you won't be able to switch the ignition on.
If you get in touch with your local LR dealer with your chassis number and a copy of your logbook, they can order you a key. I don't think they come coded though so you'd probably still need your IID tool once you'd got the key.
Post #586837 9th Mar 2021 7:35pm
Rodjules
Thanks both, Boyd Beatie looks promising, will try to avoid main steeler prices unless absolutely necessary. If I press the buy button on this one I’m going to try and do it on the cheap as a project. Right but cheap money on OE parts but labour free if I do it myself 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
Post #586852 9th Mar 2021 8:11pm
dhallworth
I’ve just done a lot of work to my SC myself and have used Duckworths LR (Forum Sponsor) for 99% of my parts.
Genuine parts aren’t as expensive as you might think for some things and are usually a far better quality.
If there’s anything you need, email Duckworths for prices, doesn’t hurt to ask and you’ll sometimes be pleasantly surprised.
Post #586858 9th Mar 2021 8:32pm
