![]() | Home > Maintenance & Mods (L322) > Audio upgrade mods - rear pillars? What have people done? |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
My best advice, don’t focus on different speakers in the back. It won’t help with getting a good quality balanced sound out of the car. Only thing it may do is make a poor sound a bit louder. You got to look at the whole picture and take everything into consideration. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
I would say the existing speakers are very good and, there's no need to replace them. I'd just like a bit more bass and a bit more oomph. Adding 2 speakers to the rear pillars seems a sensible option. |
I think that is a futile exercise. Perhaps the reason why you got tumbleweed on the other forum with this question. Bass is non directional, and needs size to shift air at low frequencies. Just not enough space on those pillars to get those kind of frequencies.
This question was not asked on the other forum.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7985 ![]() ![]() ![]() |
I’m pretty sure those speakers are only used as rear surrounds on the Logic 7 setup. Next to nothing comes out them on mine.
No they aren't wrong, it was a part of a holistic system setup. Just plonking some extra speakers there is not getting you anywhere. But hey how if you must then go for it, it just won't do anything. Just like it didn't do anything with those 80s/90s Halfords special rear parcel shelf speakers. |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 235 ![]() ![]() ![]() |
The 2 rear speakers only work with the Logic 7 switched on, that’s the case in mine anyway. |
Yeah, that’s what I thought. They are just surround speakers for the Logic 7. Im surprised they didn’t get utilised more though.....
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
I have gone down this route only last week! As mentioned they only come on with logic 7 on and when I did that one had seized and was more of a tweeter.
What I was thinking was to have either Two low/mid or two Low range only speakers in the rear pillars. I believe these are 100mm.
Think I’d do option 3, then can easily do option 1 from there, if you are not happy.
I think option 3 - they can handle a full range signal. I would wire them in series with the rear bass speakers so long as its a full range signal being sent to them. Current stable:
