![]() | Home > For Sale & Wanted > [Wanted] tow trust detachable tow bar needed |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
It seems to be a trend with those |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Had a reply from tow trust they said every swan neck has its own socket that is welded into place and therefore not interchangeable, not sure I’m swallowing this as it’s just not good business practice I’m sure there all from the same mould I may try to see if I can get one from eBay 2012 Range Rover Westminster 4.4 TDV8
sorted one from the bay, cracking condition with bag and keys £75 so happy with that just need the plug now to stop the crud 2012 Range Rover Westminster 4.4 TDV8
Dombooth188 Member Since: 09 Apr 2021 Location: Stafford Posts: 1 ![]() ![]() ![]() |
Hi, I have come across your post and in the exact same situation! Same model same missing swan neck! Would you send me any part numbers you have or advise on what to get as the bay seems to be littered with different versions. |
