Home > Maintenance & Mods (L405) > L405 4.4tdv8 coolant leak head gasket? |
BC1 Member Since: 20 Sep 2020 Location: Bucks Posts: 11 |
15th Mar 2021 10:30pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
You could try and add a dye to the Coolant and then check with black light if you can see the source. But to me it sounds like it will need spanners and ratchets and start dismantling to just take a look. |
15th Mar 2021 10:34pm |
Yes that’s what I figured. Unfortunately I know very little about cars and have no tools for this kind of job. Am totally dependent on finding decent mechanics. The Indy told me HG which he did say was very rare and he had only seen a couple and that there isn’t even a LR guide on fixing them for this engine suggesting it’s rare.
15th Mar 2021 10:48pm |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 399 |
Is there any other Independent LR specialists you can take it to for a second opinion, I've never heard of a head gasket going on the LR V8 diesels. Mine passed a pressure test initially but they reckon when they put the engine under load it started to leak. Even after I'd got it back you could still smell that sweet strange coolant smell that I thought would burn off eventually. |
15th Mar 2021 11:14pm |
I’m sorry but that Indy doesn’t sound right to me. I’d try and find another one. No guide on changing a head gasket? Are they for real? And 40 hours? Seriously? That is like a quote someone would give when they don’t want the job. Damn my 18 year old daughter would do it for that 🤣
15th Mar 2021 11:55pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
BC1, would it not be worth getting the oil cooler gaskets and thermostat housing done and while they have that much stripped down it would give them a good view and chance to find the leak.
16th Mar 2021 8:14am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i still think it will be the oil cooler leaking now you have uploaded that image.
16th Mar 2021 9:21am |
rattler 238 Member Since: 23 Apr 2021 Location: Glasgow Posts: 2 |
BC 1
23rd Apr 2021 8:08pm |
