Home > Technical (L322) > quickest way to check condition of EGRs
Chris1573
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Hi All,
Whats involved in checking the condition of the EGRs on a TDV8...? L322 2007 TDV8 3.6
Post #588050 19th Mar 2021 6:15pm
Pawl
I can't see that you can check the condition of them unless you remove them - so that you can inspect the valve heads for cracking or deterioration. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #588053 19th Mar 2021 6:36pm
Range Rover L322
. deleted by author.
Post #588081 19th Mar 2021 10:44pm
Pawl
Unfortunately, there are another couple of EGR failure modes - not just "coking up" :
1st & mild fault, but quite common is that the electrical sensor that should check if the valve is opening correctly fails - causing the Engine Management Light to come on. This isn't a big deal other than it can then fail an MOT & if ignored, can hide more serious engine faults.
2nd & catastrophic fault is that the EGR valve head craks & breaks up, with parts being sucked into the engine intake, to be difested by the engine & turbos - causing major, very expensive & fatal engine damage. This is not so common, but I know 1 such failure personally & have seen it reported a few times too.
For the cost of an LR dealer checking the consition, it would be much better value to get an independant to replace both EGRs or have then deleted mechanically & in the engine software. Paul,
Post #588089 20th Mar 2021 12:04am
