Home > Technical (L322) > 3.6 TDV8 injector stuck open?
garyRR
I've got an IID tool now and have been looking into the potential cause of black diesel soot under 100% acceleration.
I've found an anomaly on the injectors. A previous error code was that there was an injector balancing problem on injector 2 however, the IID tool is throwing this up:
As I understand, 700 - 1300 is the normal operating range but, it's 2.2 million for injector 1! Does this say the injector is stuck open / gone open loop and needs replacing or just a dodgy sensor?
Post #588852 25th Mar 2021 12:29pm
cass
cheapest way to check - swap 2 injectors over and see if the fault moves to the new cylinder. They can be tw@s to remove.
Post #588873 25th Mar 2021 2:49pm
garyRR
Is the cylinder numbering on a diagram anywhere?
They were removed recently so, should be easy to get out, aside from the access issues.
Post #588877 25th Mar 2021 3:04pm
garyRR
A glitch with the IID tool!
I've re-run the test and they are within range.
Post #588963 25th Mar 2021 9:25pm
