![]() | Home > Technical (L322) > Beep on unlock |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7992 ![]() ![]() ![]() |
So if I remember right, the double beep means it thinks something is open, so it won’t lock or set the alarm..... is that what yours is doing? It’s not locking is it?
Steve_R Member Since: 14 Nov 2019 Location: Sussex Posts: 9 ![]() ![]() ![]() |
So,
Mine doesn’t beep at all, but I know you can change stuff for the alarm as below. Possibly correct, as you say, but worth looking in the settings to try it.
Thank you so much.
OK, Do you have diagnostics equipment? Something like IID? You need to first check the CCF files as this is how the bleeps are switched off/on both on lock & unlock |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
CCF could have been updated as Craig says. Most of us have an IID Bluetooth. Invaluable for lots of things if you run an L322... |
IID is on my shopping list!!
One for sale on here just now Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Been out and about today, done a few miles, and now its stopped doing it.
I'm wondering if it was telling me the cars batteyr was low??
I have my IID tool
Clear codes and see if it returns in a day or 2 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
That’s good then. As above, clear it and see if it comes back, though from what you have found, it might start bleeping again.
