![]() | Home > General > Email from Land Rover - "Enjoy enhanced security" |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Its a problem all Manufactures face. Its just JLR are the most desirable in the UK and abroad.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
It is NOT and issue that all manufacturers face. And NOT all keys constantly transmit all the time.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
This is not an issue that I face with my FF, which I feel is more secure than any modern car that uses keyless entry.
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
I keep my keys in a faraday pouch when they are at home and it’s no hassle at all, but I don’t bother at any other time. I don’t want to disable keyless as I’ve had it for 10 years and like it and I’d be more worried about someone breaking in for the keys than scanning them from outside. But you can’t live you life that that, so I’ve got gap insurance..... |
Exactly. If they want the car they will find a way. And if they want I will hand them the keys myself |
Might i add a point that i believe many owners have overlooked? SUPERLOCKING or good old deadlocks, you need to press lock TWICE on either your door handle or remote to employ SUPERLOCKING... Now for the kicker, your full alarm is NOT enabled until you press the SUPERLOCKING...
Johnh Member Since: 08 Nov 2011 Location: Rugby Posts: 44 ![]() ![]() ![]() |
I understood if you disabled keyless entry then the key will no longer transmit unless a button is pushed. I may be wrong.
with the greatest respect guys we are going off subject here.
I disagree. You paint a very rosy picture of IT Security, especially so phone/tablet/pc. That is just not true. Now you redeem yourself a little with the comment between brackets (properly setup...) and with that proviso as many have highlighted here you can do the same with cars where the default configuration isn't good enough. |
I cannot see the point of a finger print reader, the one on my phone is not reliable at the best of times and does not work when either my hands are dirty or wearing gloves. Far more reliable to press a button on the fob.
In Germany the ADAC replicated a swiss investigation into the theft of keyless entry cars. They spent $225 on the equipment required and "stole" a number of cars from manufacturers including Audi, BMW, Land Rover, Toyota and Volkswagon to mention just a few.
Iirc that report correctly; that was slightly different and was targeting specific models with specific vulnerabilities. A bit like the known CVE in IT. I think those vehicles affected should have had a recall. But ultimate that is between the insurance company and them. It is not the case that all systems are wrong, nor that they all have the same vulnerabilities.
