![]() | Home > Technical (L322) > Central locking issue L322 2004 |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Don’t really know the answer to this one but just out of interest, does the central locking still all work if you use the key in the drivers door lock barrel?
Roger B. Member Since: 28 Apr 2021 Location: Nijmegen area Posts: 5 ![]() ![]() |
If you turn key in door once, driversdoor opens, turn it to open a second time all other doors and fuelflap unlock |
So it seems like that part of the system is okay then, but something is not allowing communication from the remote side of things doesn’t it?
The weird thing is that i can see it recognise the signals with diagnostics ( recognise each press on the button as the right button and as key 1) and that the boot unlock is functioning.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Did you re sync the key? Perhaps this would help...
As the car reads what key and which button i press ( when reading key activity with Lynx) and the key does work on the tailgate... I assumed the key was synced ( we had tried resync anyway but made no difference)
