Home > Maintenance & Mods (L322) > FBH radiator sprang a leak
Sean
England 2007 Range Rover Vogue SE TDV8 Java Black
Does anybody know where i can get one from. Mine has sprung a leak and i intend to connect the inlet and outlet pipes until i get one. anybody done this ?
Post #590006 2nd Apr 2021 4:46pm
If you fill in your profile with vehicle details, it helps when you ask questions...
Are you talking about an oil cooler, wasn't aware any fatties had an auxiliary radiator..! Pete
Post #590007 2nd Apr 2021 4:51pm
Sean
will try and fill out my profile when i can work out how.
Sorry its a 2007 3.6 and its sprang a leak just under the drivers side wing. There appears to be an aluminium radiator there and its leaking just on the joint where the pipe goes in. Is it the FBH does this have a radiator?
Thanks
Post #590008 2nd Apr 2021 5:00pm
Could be, you need someone who deals with fatties that use the devils fuel, I'm a petrol only guy...lol...
Hopefully one will be along soon... Thumbs Up Pete
Post #590017 2nd Apr 2021 5:53pm
Sean
Thanks Pete, i have just short circuited it anyway, it is for the FBH radiator.
Hopefully someone can point me in the direction of one.
I am reluctant to say this but in my 15 months of ownership its the first fault i have had. I had a disco 3 before that and that was painful. Was a member of that forum for many years.
Post #590018 2nd Apr 2021 5:57pm
rjff
Out on a limb here, but I think the rad you refer to on the drivers side is an additional engine cooler for "arduous conditions".
Mine's an 11MY but do have a look in the WM in the WIKI for yours. The FBH merely? provides heating to the engine or cabin heater matrix depending on temps. Cheers
Richard
Gap IIDBT
Post #590026 2nd Apr 2021 7:49pm
It's a well know fact that Range Rovers are the most reliable vehicle in the world..... Rolling with laughter
Wow, another thing the petrol didn't get..!! Pete
Post #590028 2nd Apr 2021 8:06pm
dingg1
Oil cooler is there on mine
Post #590032 2nd Apr 2021 8:35pm
Sean
So guys what’s the purpose of the small rad in the drivers side front end on a 3.6 v8 diesel (uk)?
Post #590048 2nd Apr 2021 10:31pm
It is an auxiliary engine coolant radiator.
2007-10 workshop manual seems to indicate this is to help the cooling system cope with arduous conditions or when towing.
"Due to package constraints an auxiliary radiator is required to maintain acceptable coolant temperatures under
arduous driving conditions such as high-load and high ambient temperatures. This radiator is located in the in
the RH wheel arch area, with cooling airflow supplied by a dedicated aperture in the front bumper. The
auxiliary radiator is connected in parallel with the main radiator, with the coolant flow being controlled by the
main engine thermostat
Post #590053 2nd Apr 2021 11:40pm
Sean
Thanks guys
As I live in Cumbria I can bypass it then until I get another one
Post #590082 3rd Apr 2021 9:30am
TJH1985
Compared to the 32k mile RR it was replaced with that in that period has had:
Exhaust gas temperature sensor failed
Rear handbrake module cracked
Front bushes
Rear diff leak
Coolant leak
Laughing Neutral Embarassed
Hope you are enjoying it, we miss it greatly! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #592182 22nd Apr 2021 11:35pm
Sean
It’s behaving brilliantly. Top car but well looked after by yourself. Shows the importance of buying a car from somebody that has looked after it.
Post #592257 23rd Apr 2021 9:00pm
