Home > Maintenance & Mods (L322) > AIR SUSPENSION FAIL | ‘06 L322 FULL SIZE SC
sierra.slt.lee
United States 2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Gentlemen!
ISSUE: Down on all fours in the morning; no, not the girlfriend Sad
I’ve since isolated my leak to the RF by watching a YT vid (diff model - same concept) where you raise to full height and then remove the fuse that allows the control module to compensate (adjust all down incrementally through the night to maintain balance).
I’ve since sprayed the bag with no obvious signs of a leak <and> more importantly all four bags were changed out three years ago.
Since this is only the RF; I would like to deduce that it’s not the control module [12] nor the front valve block [15]. Front valve block would impact both if bad, correct? Therefore best guess at this point is to just order another bag [17] and hope for the best?
Attached screen caps are of ‘07 forward, but basically the same as my ‘06 where this issue is concerned.
Any insight and/or a second on my plan before I start placing orders would be fabulous (won’t complain if it doesn’t work, rather just go to the next item).
***SOS - THANKS***
Post #590336 5th Apr 2021 6:14pm
If the replacement bags were cheap ones then I would think 3 years living on the West coast would kill them... can you see what make they are... Dunlops are known to be substandard, any of the cheap Chinese ones won't last long either...
If I was you I'd go to Arnott's and use theirs.. Thumbs Up Pete
-Click here for Thread-
Post #590457 6th Apr 2021 2:59pm
