![]() | Home > Technical (L322) > EPB - Should it come on when ignition off? |
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 ![]() ![]() ![]() |
I've noticed that when I manually put the EPB on I get a red P symbol on the dash and the rear wheels are locked solid, but if I just stop and turn the ignition off there is no symbol and the car rocks on the gearbox as though the EPB isn't on. Should the EPB come on automatically when stopped or has a previous owner disabled it? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
You have to apply it. It doesn't come on automatically.
Cheers Guys.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Indeed it is one of those "use it or lose it".
You can set it to auto in the Car Configuration Files |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
There is a setting in the IID tool to enable it automatically 👍
Does this need the GAP IID tool? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Can the l405 be coded thusly too? |
Yes & Yes... The IID can do this and yes the L405 can be configured too |
Changing the subject. Can the IID tool be used to programme the central locking to unlock all when clicking the remote fob once (instead of having to press once to unlock the driver's door and a 2nd time to unlock all doors) and, to unlock all when the key is removed from the ignition/ignition off? 2015 Range Rover Autobiography 4.4 SDV8 |
