Home > Technical (L322) > Td6 gearbox refitting
mark g
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Hi folks . Have had the box out to change the torque converter and have refitted it but am struggling to turn the flywheel to get the 3 flex plate bolts in. I have one in but its all very stiff to rotate to get at the other 2. Any ideas please
Post #590488 6th Apr 2021 6:11pm
Sounds like the TC has not located on it's fitting and is pushing against the flex plate, there is a tool to hold it engaged while you fit the box, the movement of fitting the box can make the TC come off it's seating and cause your symptoms, I afraid it's a box out again job to sort it... Pete
-Click here for Thread-
Post #590498 6th Apr 2021 6:42pm
mark g
We checked that . We left the box in park when we took it out. Have put it in neutral but makes no difference.
Post #590508 6th Apr 2021 7:47pm
Don't know what to suggest then, a TC not seated is a common issue and the flex plate should be spinable by hand, it shouldn't need anything else.... Pete
Post #590510 6th Apr 2021 8:02pm
mark g
Thanks pete. We have had the box out once already as the tc was not engaged correctly as you said. Looks like it may have disengaged again and you are probably right. Thanks for your replies pete very grateful for help
Post #590515 6th Apr 2021 8:12pm
mark g
Could it be possible that we have fitted the flywheel the wrong way round? It seems further back towards the engine block than it was
Post #590547 7th Apr 2021 6:37am
Never done the job on that engine, I suppose it's possible, there should be witness marks on the bolts that hold it and the TC on, I would have thought it would be pretty obvious but you never know...
Offer the TC up to it with the gearbox out and see if it lines up.. Thumbs Up Pete
Post #590556 7th Apr 2021 10:36am
mark g
Turns out we were both right pete. The flywheel was the wrong way round and when i put a flex plate bolt in . It pulled the tc off the shaft and locked it up many thanks for your help
Post #590595 7th Apr 2021 4:42pm
No bother, glad it's sorted... Thumbs Up Pete
Post #590600 7th Apr 2021 5:05pm
