Home > In Car Electronics (L322) > L322 Park heating with remote control
hlarry
I recently purchased a beautiful, low mileage 2011 5L s/c Autobiography which came with the Park Heating - Park Heating With Remote Control [043AV] option. However, when I operate the remote near the car, while the LED on the remote flashes red for a second or so, as far as I can tell nothing happens inside the car. According to the owners manual, if the remote "Flashes green or red for two seconds when the on or off buttons are pressed, to indicate that the signal was not received". The battery in the remote seems OK when I checked it with a multimeter.
To be honest, I am not even sure what should happen if the system was working properly as the owners handbook provides no information - is it the cabin heating and/or windscreen heater that should be turned on or what? I had a look at the Settings in the car touch screen but the only option which I thought could be relevant related to setting times for the heating to go on and off automatically and there was nothing there to do with operating the system manually with the remote.
Any thoughts on what could be wrong and how to fix it would be appreciated.
Cheers.
H
Post #590814 10th Apr 2021 8:45pm
RJPotts
Definitely red & not orange?
If it's orange, change the battery, if it's red then I wonder if it's worth trying to re-pair (not repair...) the remote?
https://www.landyzone.co.uk/land-rover/hea...st-2383219
By coincidence I've just tried mine for the first time (just picked the car up a few days ago)...... needed a new battery but then fired up no problem.
Post #604210 19th Aug 2021 7:31pm
mjdronfield
https://www.fullfatrr.com/gallery/albums/u...rt-t91.pdf
Hope this helps.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #604215 19th Aug 2021 7:57pm
