![]() | Home > Technical (L322) > 4.4 TDV8 Head Gasket Failure |
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 ![]() ![]() ![]() |
Are you sure it’s not the oil cooler rubber gaskets ? It can leak internally and you would never know. Since I did mine (for an oil leak) the very small losses I had have stopped thankfully |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
I've got the same vehicle as you & if the head gasket was diagnosed I'd be heart broken at that mileage.
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 ![]() ![]() ![]() |
I also have a 4.4 TDV8 and was losing a small amount of coolant. I have done the oil cooler oil leak and replaced the entire unit. While doing this, I also found a perished O ring that was losing coolant at this connector to the oil cooler:
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 568 ![]() ![]() ![]() |
We have to remember that MD's exist primarily to sell new, and still in warranty used, vehicles and to service and repair these. They are generally not very good at fixing anything that does not fit the above category and most of their 'technicians' won't have seen anything more than 5 or 6 years old. The indies are the places to go, they understand the common issues and are prepared to actually fault find rather than just throw their customer's money at the problem in the hope they srike lucky.
Rodjules Member Since: 03 Mar 2016 Location: Bishops Stortford Posts: 68 ![]() ![]() ![]() |
Thank you all for your advice and comments. Confirming my thoughts that I hadn’t seen anything on the forum regarding HG on the 4.4. I went into the MD and spoke to the senior technician who is now on the car and pointed him towards the oil cooler gaskets. Will wait and see what they report back but think I will get a second opinion before authorising HG replacement. To be fair I have used this MD for many years and they have always been very good. Will keep you all in the loop on how I get on |
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 ![]() ![]() ![]() |
If all the work is at no cost to you then just let them do it. If it still leaks after that then back it goes in to the MD. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
and get them to check all those items Matt pointed out too |
So latest update chaps. Have taken the car away from the MD after a week of no progress and head scratching ! According to their Lead technician it’s not the HG but he can't find a leak (am I sure it’s loosing coolant, patronising ?). Now going to take it to a recommended Indy and get them to change the pipes that Matt has suggested and see how we go. Not the Oil Cooler gaskets as these were done in Dec when the EGR cooler was replaced.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Although mine is a 4.2 supercharged, it took me about 6 months to track down a small coolant leak and it only became detectable when it got worse, if its dripping onto something thats hot it just flashes off and you never see any evidence under the car.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
My indie who has 25 yrs LR experience is currently fixing a 2011 4.4 tdv8 which has the same symptoms - he suspects the egr cooler and will let me know how he gets on. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
My 2011 had an annoying leak mate and it was the top hose to thermostat housing. O ring had gone. I pressurized the system and saw it straight away using a torch. I adapted an old expansion bottle cap to put some pressure in the system. |
Bring back jubilee clips instead of inferior composition O rings! |
I agree. I think they went down this expensive hose connection system purely for ease of production because you just push them on and the job is done. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Thanks Matt ![]() I'm sure I have a small weep somewhere so might get it pressure tested or just buy that tester myself. Might come in handy on my "new LR project" too ![]() Anyway, 1) Have you got the part number for hose connector to the EGR that you bought then used the O ring out of? 2) The other leak you had. Did you just buy an O ring? If yes, where did you get it from and size etc? Ta Rob ![]() Offers: https://www.ebay.co.uk/itm/PRO-Radiator-Co...Sw2tRgWc2I Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
