Home > Maintenance & Mods (L405) > Underbody gearbox cover bolts
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Hi all
After a recent visit to the dealers for some transfer case wiring repairs have noticed a slight rattling from underneath and found that the 4 small 10m head outer bolts on the panel underneath the gearbox are missing or just about to fall out as they have obviously not been tightened (Should I be surprised? ) )
just wondering if anyone knew the bolt thread sizes or part numbers
Thanks in advance
 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #591438 16th Apr 2021 5:22pm
might be something in the WM but i would be inclined to take one of the remaining bolts out and measure it ? ... - .- -.
Post #591439 16th Apr 2021 5:27pm
Rob99
^Good tip Thumbs Up
I took a couple of those out when I fitted my side steps recently, think you'll find they are M6. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #591442 16th Apr 2021 6:08pm
aljo
Post #591444 16th Apr 2021 6:19pm
Merchy
Get one bolt as a sample, measure and get same from do-it-yourself shops or engineering supply places, will save you a fortune, last place I would ever go for general bolts etc is a MD Censored
These places will have the same bolts in any material you want. Thumbs Up
Edit - Plus the internet for bolts / washers.
Post #591445 16th Apr 2021 6:21pm
Rob99
According to the WM there are 2 sizes, M6 and M10 and there are 10 of them fixing the undershield so you might want to make sure they are all there Whistle
I think the one's you show are the 4 that hold the 2 fibre side panels so aren't structural and would be M6. The M10 ones are used to fix the undershield to the chassis, hence 60Nm torque.
Post #591447 16th Apr 2021 6:24pm
aljo
Its the smaller outer ones that are missing and have checked all the others are there and are tight Big Cry Big Cry Big Cry Thumbs Up
beggars belief that the dealers cant do a simple thing like tighten a bolt up Big Cry Big Cry Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #591450 16th Apr 2021 6:30pm
aljo
Think I've narrowed it down to this part number Thumbs Up
Post #591453 16th Apr 2021 6:41pm
Kot
Its terrible.
You need to complain about this, what else are they forgetting to complete properly.
They should at least install new bolts for you, or send you a set as you have lost all faith in their ability. 2018 SE SDV8 4.4 Byron Blue
Post #591457 16th Apr 2021 7:02pm
