Home > Technical (L322) > Coolant Leak
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Coolant Leak
Hi there,
My Supercharged gave me the dreaded bong followed by 'check coolant level' last night. On checking, the level was two inches below the min level, so took around 3/4 of a litre to top up.
It looks like some is leaking from what I guess is the 'bleed screw' on the top of the expansion tank. I'll try just tightening it, any other advice?
Thanks,
David 2012 SDV8 Vogue SE
Post #63597 12th May 2011 2:33pm
pretlove
every now and then i get that messege as well but when i check it has only ever lost a small amount of water and ive still not managed to find where its going Sad this may happen twice in one week or once in a month its an odd one "RANGEISM WILL NOT BE TOLERATED"
Post #63653 12th May 2011 7:03pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Check where your LPG installer has tapped into the coolant system. Sometimes the jubilee clips just need nipping up a touch. Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #63709 13th May 2011 6:45am
Herdwick
United Kingdom 2012 Range Rover Westminster 4.4 V8 Santorini Black
Have a similar problem,
loses just a very small amount over time, when in went in for a service, dealer noticed that the radiator had marks on it where there appeared to be a small 'weep' from the radiator, so in next friday for a new radiator under warranty.
Post #63715 13th May 2011 8:19am
