Home > Maintenance & Mods (L322) > What should this plug into?
Danwilderspin
So this wire with plug was dangling between the rear driver wheel and the rear diff - it’s been off a while as the pins are corroded - got no faults or anything but I can’t find what it may be for - any ideas?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592199 23rd Apr 2021 12:22pm
kevinp
Electronic rear diff?
Post #592214 23rd Apr 2021 1:57pm
Merchy
As you currently report no indicated faults - Try every single feature your car has, to see if one feature is not working, some items may not indicate a fault when disconnected, but may indicate a fault when is does not respond to signals when operated. ie like locking diff as in Kevinp's post.
Post #592215 23rd Apr 2021 2:05pm
FBH fuel pump ? .
Post #592218 23rd Apr 2021 2:12pm
Danwilderspin
I think mine is this as a 2007 supercharged but if that is what this is where does it plug in? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592238 23rd Apr 2021 4:24pm
Danwilderspin
Joe90 wrote:
FBH fuel pump ?
Looked at the ediff it looks like a different plug but, looking at the fbh pumps on eBay that looks like it could be it...
Next question are these prewired for FBH if that's what this is or has it been removed? any idea how to tell? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592239 23rd Apr 2021 4:32pm
Weegie
As a suggestion, FBH was standard on diesel models and an option on petrol models. I would think that the same loom was used for all models as being easier. I think it is probably an FBH plug but as yours is supercharged - no FBH. John
GAP iiD BT-Sold
Post #592242 23rd Apr 2021 6:29pm
Danwilderspin
That makes sense - thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592273 24th Apr 2021 9:17am
