Home > Technical (L322) > Manufacturer recs new bolts?
pld118
When replacing component parts, why do manufacturers recommend replacing the existing mounting bolts with new bolts?
Post #592259 23rd Apr 2021 9:04pm
mjdronfield
I’m not sure about all of them, but i know some bolts are made to stretch when fitted correctly and need to be replaced once undone. I’m no expert here, so don’t know what they are called.
There will probably be other reasons too... like taking more money off us.... 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #592261 23rd Apr 2021 9:19pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
imho many are sold with a thread lock compound already on the bolt, so reusing is fine just use an appropriate thread lock. Obviously dont do this with stretch bolts and make up your own mind about some high stress bolts. Personally I normally reuse all bolts except very high stress bolts on some parts of the suspension.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #592262 23rd Apr 2021 9:50pm
Merchy
To add to the above comments, 'Stretch bolts' I have encountered have always been for the engine head(s), due to the composition of the metal they stretch to a set measurement at a pre-prescribed torque. ( Or turning angle )Once used they will basically not stretch to the correct settings again, due to the loss of elasticity (ductility )hence they are single use only. Generally thread lock is not used with stretch bolts unless the makers specify it's use.
On large ( Marine ) engines studs are stretched using hydraulic jacks, with up to 1600 bar pressure then the nut is tightened by hand, checked for no clearance with a feeler gauge and the hydraulic pressure released. The elasticity ( or stretching ) of the stud ensures the correct tension is applied, but due to the metal composition, these are re-usable and the term 'Stretch bolt' does not apply.
In some applications, ie Brakes, bolts can suffer from excess heat, heating and cooling a bolt will alter the metals properties. If a bolt is heated and suddenly cooled, it will effectively be hardened, thus changing the ductility, making it less elastic and more brittle, thus weakening the bolt, so safety could be affected. One of the reasons they change these bolts, plus corrosion etc.
Bolts subject to heat on say an exhaust manifold will not cause a safety issue on failure, unlike on a braking system.
If you have read this far, then award yourself a large libation or two, and maybe even some tasty comestibles, AKA a real ale and crisps. Thumbs Up
Post #592264 23rd Apr 2021 10:42pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Considering they cost less than a cup of coffee I don’t even think twice and like putting new bolts on my cars when replacing parts.
Post #592266 24th Apr 2021 12:07am
