Home > Technical (L322) > 4 weeks for first oil leak.
Chieflongshin
United Kingdom 2011 Range Rover Vogue 4.4 V8 Barolo Black
Morning all
I’ve just noticed my 2011 4.4tdv8 has left three drops of oil on my drive. It’s not haemorrhaging but something is there . I understand the oil coolers can go. Are there any other areas they can leak?
I was curious though (mechanically manlnourished here) what type of price would be competitive for a genuine oil cooler if it is this upon investigation to be changed.
Thank you
Post #592401 26th Apr 2021 9:16am
DrRob
Usually oil cooler gaskets. Check the Wiki on here - top right of page
Sometimes oil pump gallery plug
Sometimes a turbo
See my log here. Point 20. I had the full house Rolling with laughter
https://www.fullfatrr.com/forum/topic44115...p;start=75
Easy to check oil cooler gaskets. Guide on here somewhere. Engine cover off, pollen box out with 2 nuts and then peer down into back of V. It will also smell when hot and drip from belhhousing area underneath.
Where are you located? Your profile is not specific enough for us to recommend where to get decent expertise Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #592404 26th Apr 2021 9:35am
Chieflongshin
Thanks for the quick reply. I’m close to bishops heritage so I’ll likely see them.
Post #592407 26th Apr 2021 10:12am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Also, check your coolant tank for signs of oil?
Post #592417 26th Apr 2021 11:15am
Jayk69
i did mine took me 4hrs with my 11 year old apprentice on hand and plenty of tea!!
i used a part from Advanced Factors made by Nissens did the job back in feb i think no issues since.
i now need to change my expansion bottle though as there was oil in the coolant. I also did a oil change at the same time as i suspect there was coolant in there even though there was no sign of it.
the procedure is in WiKi have fun Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #592434 26th Apr 2021 2:12pm
