Home > Maintenance & Mods (L322) > Anyone know a good paintless dent removal?
Andy
A freak gust of wind on an otherwise calm day and a metal cabinet door hits the side of the car!
It’s hit the door edge where it meets the plastic grille. It could’ve been a lot worse I suppose.
I’ve seen PDR firms removing door edge dents on YouTube bit theyre all American based. Having said that, it tells me it can be done.
Here is the dent. It looks worse than it is as the reflection around it accentuates it a lot.
I’m West Midlands based and can travel if need be.
Thanks in advance 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #593251 5th May 2021 1:00pm
Merchy
Someone like 'Dent Devils' mobile specialists maybe, ( There seems to be quite a few different specialists ) may not be so easy as it's right on the edge, maybe worth a go contacting one of them and then E-mailing them a photo. See what they think.
Post #593253 5th May 2021 1:11pm
rjff
My neighbour used DentDevils on his 10 C class Merc and was pleased. The dealer he bought his 14 E class from used the same company when said neighbour pointed out some marks.
I don't recall how close to the edges of the panels the repairs were. DD will come to you.
Only my experience and not in any way connected to DD.
HTH Cheers
Richard
Gap IIDBT
Post #593254 5th May 2021 1:13pm
Andy
I emailed Dent Devils a photo of the dent and they said they can’t do it. I’m suprised at that to be honest. I do have a number to someone who does rectification at JLR so I’ll see what he says. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #593255 5th May 2021 1:15pm
Kot
I do remember Ed China having a glue system for repairing dents.
Something similar like  2018 SE SDV8 4.4 Byron Blue
Post #593256 5th May 2021 1:22pm
Andy
That looks pretty good. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #593257 5th May 2021 1:28pm
kevinp
I'd get some felt furniture pads, then place a piece of stiff wood either side on top of the felt pads and go gentle with a g clamp.
Post #593262 5th May 2021 1:52pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Paintless Dent Removal (PDR) is generally done by using tools from behind to push out the dent. That is why something like that on the edge is probably not doable with PDR as the door skin folds around and stops you getting to the back of the panel edge.
Other methods are glue or tacking a small welded pin onto the spot then using a puller to lift out the dent. The first is paintless, the second needs paint. I doubt you will get enough leverage with glue given again the proximity to the edge as you are trying to unfold the ding against folded metal not a flat panel so there is a lot more resistance in the metal.
I would probably ask a couple of body shops for their opinion - again not an ideal place to "fill" as its so close to the edge you run the risk of the filler coming out.
So in short a real bu**er of a job Big Cry
All the above are an amateurs opinion, so as you said, worth bouncing of an expert.
cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #593263 5th May 2021 1:54pm
MonkeyMan
I suggest you give these guys a call: https://tdngroup.co.uk
AFAIK they train a lot of the dent removal guys across the country, and bring in a lot of the tools that are used.
Friend of mine works there, and some years ago he managed to completely restore the side of an old Honda Prelude that I had which some **** reversed into in a car park. didn't leave a mark. Your repair may be a tricky one, but this would be my first port of call.
Post #593274 5th May 2021 4:35pm
ur20v
A Trap
This cannot be done with PDR because it’s on the edge where the metal is folded, it’s 3 layers thick there, it will need normal body repair to knock the dent out then fill and paint as the panel beating will damage the paint.
Post #593281 5th May 2021 5:45pm
Strider
kevinp has the right idea except I wouldnt use wood or any material cushion as it would absorb the metal
"peak" on the inside of the door edge and not push the material back into place.
My idea: Get 2 small pieces of 1 inch angle iron, file and sand one face on each piece until its smooth and flat, finish with
wet & dry.
Make sure it is perfectly clean with no dust or grit on the polished surfaces. Now get some masking tape and stick only
one layer on the surface of the one to be used on the visible outside skin.
Remove the side vent, tape the 2 angle iron bits in place and using suitable tool (G clamp etc ) clamp the sandwiched, area checking as you increase the pressure.
Good Luck
Post #593293 5th May 2021 7:49pm
ur20v
A Trap
The door has a curve, clamping flat metal to it to ‘push’ the dent out will just add a flat to the door to panel beat out, also the back of the door there isn’t flat either.
It’s not a difficult job to panel beat straight but will need paint.
Post #593400 6th May 2021 7:31pm
