Home > My Range Rover > A dream has come true! My new to me 05 td6 vogue!
Jonnys19882
United Kingdom 2005 Range Rover Vogue Td6 Adriatic Blue
I thought I would introduce myself.
Yesterday I collected a 2005 td6 vogue after wanting one since they came out all those years ago.
I was brought up around Landrovers. We have had lightweights, 90’s, disco 1 and 2 and 1 classic RR with an Isuzu 2.8 conversion. We used to 90s to comp safari.
It’s been a while, about ten years since LR ownership and the time finally came when I could justify to get one.
That’s where this came in.
It’s done 144k had a new gearbox 35k ago, new turbo and a massive file of history.
The body is in great condition as is the interior and obviously looks well cared for and maintained!
Typically on the drive home the air suspension inactive came on and the battery is on its way out. I popped into my local indi who put it on Diagnostics and told me it needed a new compressor. He told me to get on from eBay and he will fit tomorrow afternoon. I’ve ordered a new battery and hopefully that and the compressor will sort it out.
Also some other jobs to do are: investigate heavy steering, get the driver heated seat to work, get the heated steering wheel working, re gas the air con and give it a good valet!
Already love the car.
I’m sure they will be lots of questions to come!
Cheers
Post #594019 12th May 2021 5:31pm
Jonnys19882
Post #594020 12th May 2021 5:32pm
Jonnys19882
Post #594023 12th May 2021 5:37pm
just like my very first one [cairns blue?]
Thumbs Up ... - .- -.
Post #594025 12th May 2021 5:46pm
Jonnys19882
It is indeed! Also has a ff sticker in the back as well. I guess it may have been on here before??
Post #594026 12th May 2021 5:48pm
Looks lovely, 2002-05, IMHO the best looking model....
Enjoy... Thumbs Up Pete
Post #594039 12th May 2021 6:31pm
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
Great colour and I'm always amazed at how nice the leather looks given the age and mileage. Looking forward to seeing more... 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #594040 12th May 2021 6:34pm
Jonnys19882
New compressor and battery fitted today, it goes up and down a lot quicker now!
Post #594148 13th May 2021 3:44pm
Good Job... don't forget to reset the windows and sun roof... Thumbs Up Pete
Post #594151 13th May 2021 3:55pm
John61
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Looking good , interior particularly nice. Would be worth checking the pesky rear wheel arches and sills Holland and Holland Range Rover By Overfinch
Post #594154 13th May 2021 4:30pm
Jonnys19882
The wheel arches are quite good with only a little bubble thus far. Next is the steering I feel it’s the sensor behind the drivers wheel....
Post #594155 13th May 2021 4:41pm
Jonnys19882
Nice day out today! Radio stuck on LR screen has had the Bluetooth bypass already so I’m sure it’s just a loose connection
Post #594337 15th May 2021 5:34pm
Most at that age suffer from heavy steering... A good test is to get it on an A road and turn off/exit from quite a high speed braking heavily... Then when you drive around the bend exiting the A road, see how long it takes for the steering to lighten up! Some take an excessive amount of time, this can be the valve on the side of the rack as you mentioned... If it doesn't lighten up, then you must have an issue elsewhere?
Post #594402 16th May 2021 5:11pm
Jonnys19882
Very interesting. I will try that technique.
The steering when stationary is quite light it’s just when you start to move. I love the car though. The only other point is that the HDC inactive light comes on sometimes when starting although it has just has a new battery. The car cranks over very quickly though. I wonder if it’s a drain somewhere or just some character!
Post #594408 16th May 2021 6:15pm
Jonnys19882
It went lighter! Must be the valve
Post #594538 17th May 2021 9:01pm
