Home > Maintenance & Mods (L322) > Squeaky brakes
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
Squeaky brakes
Had my pads and discs changed by a local garage but they are squeaking some of the time now - most noticeable when turning slightly right and seems to be coming from driver’s side front wheel. The garage have had it back and changed the discs and pads again (at their cost). The original replacement discs were Textar and they’ve now changed to Brembo.
Just wondered if anyone has had similar experience and if so how they resolved it? Car is facelift 2009 TDV8 with 94k miles
Post #594572 18th May 2021 8:01am
Dolphinboy
Just had my brakes done with all gen LR parts and still squeak exactly like yours.
Post #594578 18th May 2021 9:06am
nickt68
Thanks Dolphinboy - guess the answer must be to keep the window shut then Very Happy
Post #594591 18th May 2021 11:57am
knwatkins
Squeaking is usually caused by high frequency vibration of the pads between the surface of the disc and the piston of the caliper. Genuine Land Rover pads mitigate against this through a self adhesive backing on the shim that bonds to the face of the caliper pistons. Another way to achieve this is to apply a ceramic grease (not copperslip or any other mineral oil based grease as it will rot the piston boots over time) to the face of the pistons to achieve the same effect. I did this when fitting my aftermarket ceramic/carbon fibre pads the other week and they are silent. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #594620 18th May 2021 4:13pm
nickt68
Thanks knwatkins, I will pass that on to them as it’s going back in on Thursday. I know that they did re-grease when it first happened but not sure what they used
Post #594631 18th May 2021 5:59pm
Wait till they bed in, they usually get better, they could be glazed as well, in which case do a few heavy brakes from motorway speed to knock the glaze off... Thumbs Up Pete
Post #594643 18th May 2021 7:55pm
