Home > Technical (L322) > advise please wear does this connect
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi al under rear end getting ready to coat rear subframe and sean this resting on the D/Side rear propshaft inner joint so went in through wheel arch and pulled it through cant see wear it goes 2 wires only it has a fir tree clip on it but just cant see wear it goes many thanks oggy
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #594834 20th May 2021 6:36pm
Difficult to see, could be the brake pad wear plug.. you should have one O/S front and one O/S rear... Thumbs Up Pete
-Click here for Thread-
Post #594855 20th May 2021 11:45pm
FBH pump connector (you may not have one, but the wiring is there) .
Post #594871 21st May 2021 9:32am
oggy
hi all many thanks for your help not the brake wear wire that is all fine but thanks . i think joe 90 has got it fbh pump connecter i have zip tide it up . just to ask is that fbh pump normale at the rear of the sub frame joe 90 thanks oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #594942 21st May 2021 7:27pm
Yes, if you have an FBH, the fuel pump for it lives up on top of the subframe just past the upper wishbone (looking from the side). It is a pain to get at or even see it unless you lower the subframe a bit. Consult RAVE or the later WM for more info. .
Post #594955 21st May 2021 10:42pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Mine has some spare plugs in that area, which I think are for the tyre pressure sensors if they were fitted.
Post #595015 22nd May 2021 6:49pm
oggy
thanks for every ones input i would say joe 90 has got it i have had a look at my build sheet and no pump fitted so have zip tied it up out of the way thanks to all oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #595030 22nd May 2021 8:03pm
