Home > Technical (L322) > Smoking At Start |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Blue smoke is burning oil, and I wouldn't ignore an oil warning light. Problem with oil warning lights is that they don't tend to come on until oil pressure is dangerously low, around 5psi or so. Actual oil pressure can be read at a main dealer using diag, or perhaps some decent generic diag tool. But I would strongly advise against driving it until you know what the problem is.
26th May 2021 11:00am |
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 |
Thanks Sam. I am good with most stuff and the rest of the car is fine, but engines are not my thing. I took the oil filler cap off when the engine was hot, anyone tell me if this is normal?
26th May 2021 11:44am |
Yes that's perfectly normal. However you have stumbled on a good way of telling if your piston rings are shot and that is why you're burning oil; if you start the engine with the cap off (Wrap a bit of rag around the filler neck), and just rest your fingers across the top of the filler neck where the cap would normally be. You should feel a light fluttering between your fingers which is normal, but if it seems to be blowing quite hard , or 'breathing heavily' in technical parlance, then it's a good indication of worn rings. What happens is that with every combustion cycle, some of the pressure caused by each of the explosions bleeds past the piston rings and over-pressurises the crankcase, and that pressure then tries to escape wherever it can, hence the term 'heavy breathing'. What also happens is the piston rings don't scrape all the oil back down the bores, and some of it gets past the rings, which then gets burnt on the next combustion cycle and you get blue smoke and an ever reducing amount of oil in your sump.
26th May 2021 2:08pm |
The saga continues, still getting the oil light on when idling. Read that it is probably the oil filter seal. This is what I found the locating lug of the filter hadn't fitted home and the filter was crushed when I fitted it. It is possible this has starved the turbos of oil and that is why there is smoke. I am getting a new filter today.
27th May 2021 8:49am |
New Bosch filter has been fitted, seems much more robust that the ebay special. I still get the odd puff of smoke on starting, but the car is fine plenty of power. Still need to get my egr's mapped out. Just leaving this here for anyone else who screws up an oil filter install.
29th May 2021 2:41pm |
The RR Bandit Member Since: 31 Oct 2019 Location: Teesside Posts: 29 |
Is there just a puff of blue smoke initially on start up then goes back to normal? From experience I’ve found that that is valve stem seals passing oil into the cylinders. If you leave it for longer between start ups it generally gets a larger amount of smoke as more oil has seeped into the cylinder.
30th May 2021 9:15am |
Yes it does sound like it Bandit. I can live with the puff of smoke as the car doesn't get used a lot, is this going to be a terminal issue or can I just live with it do you think? Worse if left longer as you say. Thanks very much for the post! 2009 TDV8 3.6 |
30th May 2021 2:35pm |
I honestly couldn’t comment on if it would be a terminal issue. From what I understand of the issue it causes misfires especially as it’s a diesel. If it is your valve stem seals then there is cheap solutions such as valve stem seal conditioner. From what I understand the issue is caused by the seals going hard due to excessive heat so on your next oil change you could try replacing 1 litre of your oil with the conditioner and running it. The should soften the seals and remedy the issue.
30th May 2021 5:28pm |
Thanks really appreciated the input!
30th May 2021 6:34pm |
Best of luck and hope you get sorted 👍
30th May 2021 7:23pm |
Podge_healy Member Since: 01 Oct 2016 Location: Kerry Posts: 5 |
Hello , Ive got the exact same issues you have re smoke ,any updates ? |
23rd Jun 2022 11:44pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 189 |
My air filter was exactly the same and that’s why my turbos gave up on the motorway- £3k later fixed but painful experience- only had the car 2months prior 😂 2007 TDV8 Vogue SE
24th Jun 2022 10:10am |
