Home > Technical (L322) > Centre dash vents control wheel stuck in the red!
Ron Greevar
United Kingdom 2011 Range Rover Vogue 4.4 V8 Galway Green
Hi guys,
I am getting through the 'to do' list on my new to me 2010 60 plate 4.4 TDV8 Vogue.
The latest item: The car arrived with the temperature control wheel for the centre dash vents stuck firmly in the hot/red zone.
I have removed the fascia plate. A green Bowden cable was attached to the arm behind the wheel but would not move using the wheel. I detached the cable from the nipple and the wheel moved freely. But the cable will not move.
So, has something happened at the other end of that Bowden cable (presumably opening/closing a flap?) causing it to stick, where does it go and how do I get to it?
Your input please, always gratefully received.
Ron Thumbs Up
Post #595671 28th May 2021 5:25pm
mjdronfield
The workshop manual is in the Wiki to download....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #595674 28th May 2021 6:03pm
Ron Greevar
Thanks - Mike?, again.
I will check out the manual on the Wiki but, rather than spoil my starting to come out of lockdown Friday night worrying about it, can this actuator - presumably where the Bowden cable terminates, be got at without tearing down half the car?
Ron Sad
Post #595680 28th May 2021 6:42pm
mjdronfield
I’m Mark mate. I’ve never done it, but it looks like it might be a bit of a strip down. It’s one of those times that maybe an endoscope with a light might be an investment 🤣.
I’m sure someone on here has swapped the entire unit, so might know if there is a way just to have a look easily.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #595687 28th May 2021 7:56pm
Ron Greevar
Hi Mark,
Hopefully sorted the problem with the sticking control wheel. There was a burr on the quadrant gear between the wheel and the cable preventing the wheel from moving. A chisel scalpel blade got it off and a few drops of silicone lube on the gears, down the cable and on every other hinge I could see in the assembly has hopefully sorted it.
Will road test it tomorrow (after reading the owners manual to find out what that vent assembly actually does!)
Thanks for your input.
Ron Thumbs Up Thumbs Up
Post #595869 30th May 2021 5:38pm
