![]() | Home > Technical (L322) > Normal Kickdown Operation? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
Normal I'd say, happens in the 4.2 sc too |
RosieL322 Member Since: 20 May 2021 Location: County Durham Posts: 26 ![]() ![]() ![]() |
Thank you |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Thats not kickdown, thats just dropping down a gear, kickdown occurs when you floor the accelerator and it should almost redline the revs before changing up to the next gear. BMW i3 Electric Car
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Yeah mine (TDV8) does that going up and going down hill - I do believe it's part of how the transmission (8-speed Ford made in Mexico if what I've read is correct) is set up or computerised (is that correct) so as to give safety - being in lower gear puts you more in control and doesn't let the vehicle run away from you - and lessen engine wear but also is connected to fuel economy and environmental considerations... On longer, more drawn out climbs/ascents I might go into renegade mode and use the paddles to over-ride from D and pop up a gear or so, as I don't like to hear the sound of the beastie going above 2000 unless on the level, and preferably on a motorway.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
The OP has a 2007 3.6, so not the 8 speed box. I’m sure it’s 6 speed....
Yes it’s a 6 speed ZF unit and kickdown is the wrong term, it drops a cog on gentle inclines. 👍 |
I think the cruise control might also predict the “rate of speed change”, ie, it might not need to change down as such, but does to ensure speed does not drop at all. I suppose you could knock cruise off and manually knock it into top and see if it’s happy, just to see.
Thanks for all the comments, if it’s normal, then I’m happy. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Yep my L322 does the same, kickdown is when you feel the little switch on the floor engage (when the accelerator pushes it) and 45 seconds later it changes down too far to a gear that is almost out of puff and then changes up again. |
Amazing how the kick-down reaction can vary from motor to motor; mine is about a single human blink and the acceleration is close to neck breaking... My TDV8 is actually quicker in both reactions and speed/acceleration than my jag XK8 was, and that wasn't slow... Maybe the XK wasn't playing at its best?!? |
Yes, you do have to make sure you have a clear bit of road in front of you if you are going to wake up the 4.4 TDV8. The 8 speed box helps there too.
