Home > Technical (L322) > Help Sliding pin spanner size? see500020 Front brake removal
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Hi All,
Hoping someone can help me, I am trying to replace the front brake caliper.
I am trying to find out what size spanner can be used to hold the sliding pins (see500020) while I unbolt the slider pin bolt(SMV500010).
Its proving a bit tricky as my spanner set only goes up to 17mm but is on the chubby side and does not get in under the lip on the slider pin so its had to see what size will be needed.
Really appreciate the help on this one. Bow down
Post #596133 1st Jun 2021 9:10pm
Merchy
13mm for the bolt, 16mm for the sliding pin. First make sure you scrape / brush off any rust / scale that may have built up on the flats.
Post #596140 1st Jun 2021 9:59pm
Cooper1275
Your a gent! Thumbs Up
Il have to source a skinny 16mm spanner
Post #596145 1st Jun 2021 10:14pm
Merchy
If you cannot find a 'skinny' spanner, buy a cheap one and use an angle grinder, file or similar to reduce the thickness. Hope it all goes well Thumbs Up
Post #596155 1st Jun 2021 11:13pm
As above, i have a slim set of spanners for this... Thumbs Up
Post #596164 1st Jun 2021 11:55pm
Cooper1275
16mm is too small. Big Cry
These are the TRW front calipers.
Post #596220 2nd Jun 2021 5:20pm
Cooper1275
A 17 fit it in the end.
Job done, prob spent more time looking for a spanner than I did working Rolling with laughter
Post #596226 2nd Jun 2021 7:58pm
Merchy
Ah well, at least you got there, my bits are all Pagid, must be slight differences in sizes, typical RR problems Banging Head
Post #596231 2nd Jun 2021 9:18pm
