![]() | Home > Maintenance & Mods (L322) > Tinney noise from rear of car |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Ahhh, what you have there Sir, are the components that hold the hand brake, brake shoes in place. You will have to open it all up. From what you have said, the hand brake unit brake shoes must be binding, I would investigate this sooner rather than later.
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
Great thanks |
Can you buy that part separately or the whole handbrake mechanism? |
Yes you can get them separately, see below link, these can become loose due to the hole in the backing plate being enlarged due to rust.
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 134 ![]() ![]() ![]() |
If the hole has rusted in the backing plate, then rather than replace the backing plate you can use brake retainer cup washers - https://www.bimmerforums.co.uk/threads/e46...avy.64462/ will give you the idea. There's a writeup on this site somewhere as well IIRC. Note that there are different size cup washers for different brake manufacturers - might need to try a couple to find the right one. |
